1992 Jeep Wrangler temperature goes high at high speed
210,000 MILES • 6 CYL • 4WD • MANUAL
RSIMON70
I have a jeep wrangler 1992 4.0 engine manual transmission. The problem is that the temperature goes up when going over 65 miles (up to 3/4), I have the engine rebuilt (this happened before this too), new radiator, new thermostat, new water pump, I replace the fan to an electrical system, and there is no obstruction for the air to flow in the front. Other wear issue is that the manifold goes red hot when over 2500 RPM. I replace the distributor too, but now I was told that this could be because of a bad computer, any ideas of what can be wrong or if it's possible to be cause by the computer?
Sep 9, 2008 at 7:13 PM
BMRFIXIT
  • 19,053 POSTS
Was the same head used when you had engine rebuilt
u need to find if it was checked
had similar issue head was no good
computer does not control the coolant system specially u had installed an electric coolant fan
so I would say its not the computer
exhaust manifold turning red ?
check firing order ,timing ,and for misfire
check exhaust back pressure and catalytic converter
Sep 9, 2008 at 10:56 PM
RSIMON70
It looks like all is ok, I spoke with a mechanic and he use a diagnostic computer and he said that after 2500 rpm the engine timing goes to 0 degrees, can this cause both issues, the overheathing at high speed and manifold to turn red hot??
Sep 10, 2008 at 7:07 PM
BMRFIXIT
  • 19,053 POSTS
Manifold red :Timing will do it for sure
and possible overheat too but ,
I would keep an eye on the overheating issue until all OK
good luck
Sep 10, 2008 at 10:50 PM
