1992 Jeep Wrangler Manual steering
115,000 MILES • 4 CYL • 4WD • MANUAL
KESMAN22
I have a constant problem with the manual steering gear on my wrangler getting loose causing a lot of play on the steering wheel. I have been told that the steering can be changed to power steering because the hole for the bolts are there. Is this true? and what parts need to be changed?
Mar 12, 2008 at 6:01 AM
ROB66ERT
  • 18 POSTS
I have a 90 jeep wrangler, with the 4cyl. it came from the factory without power steering, It now has power steering, I became disabled and had a hard time driving it with the oversized tires, yes I do believe the 92 is the exact same as the 90 model, and it is pre- set for the power steering, I purchased all my parts used and accomplished this all for under 150.00, did the labor myself,was not as tuff as it seems, you will need to find a power steering pump,power steering gearbox, and highpressure powersteering lines. I found it all on ebay, piece at a time, I also found several used systoms decently priced...and let me tell you it makes all the difference...when you get started let me know I will be glad to help if I can
Mar 31, 2008 at 7:12 PM
