1992 Jeep Wrangler hydrolic clutch
CHADTC
Transmission problem
1992 Jeep Wrangler 4 cyl Four Wheel Drive Manual
i asked about my clutch pedal or lack there of yesterday but put in the wrong year by mistake. i dont have a 2002, i have a 1992. i have put a new clutch in including the internal slave cylinder and bled the line several times but cant seem to keep any pedal pressure. it works ok rite after bleeding it but i have to pump it several times once i get down the road. please help still shiftless.
Feb 9, 2010 at 10:09 PM
2CARPRO JACK
  • 11,533 POSTS
No problem. same applies
Sounds like the only part left is the clutch master.It is just like a brake master and can suck air in if the seals start going bad.If you have a pedal, then you have most likely bled it properly, for it to go away means air is being introduced into the system. Look at the back of the master under the dash for any signs of leaking or sweating where the rod goes in from the pedal, this isnt 100% but usually a good indicator of the problem
Feb 9, 2010 at 11:07 PM
