1992 Jeep Wrangler crank sensor
1992 JEEP WRANGLER
99,999 MILES • 6 CYL • 4WD • MANUAL
SANTI22
how to test, have replaced coil and cap/rotor. Still not starting. I want to test crank sensor
May 9, 2008 at 10:26 AM
BMRFIXIT
  • 19,053 POSTS
use an ohm meter or just replace it
check also the relays
u have no spark
did you check for fuel pressure
May 9, 2008 at 11:25 AM
