1991 Jeep Wrangler BRAKE LIGHTS
198,000 MILES • 6 CYL • 4WD • MANUAL
CLREED756
I RECENTLY REPLACED MY BRAKE LIGHTS AND NOW THE BRAKE LIGTHS DO NOT WORK. THE RUNNING LIGHTS AND TURN SIGNALS WORK FINE, JUST NO BRAKE LIGHTS. I REPLACED THE BRAKE SWITCH ON THE BRAKE PEDAL AND CHECKED ALL THE FUSES. ALSO I PUT A METER ON THE HARNESS IN THE BRAKE LIGHT AND PUSHED THE BRAKE PEDAL AND NO POWER IS TRAVELING TO THE HARNESS, NOT SURE WHAT TO DO NEXT, CAN YOU HELP?
Feb 21, 2009 at 5:28 PM
PCMAGMAN
I am having almost the exact problem on my hot rod. The brakes lights were working fine. I cut the brake light wire to add a new 3rd brake light. Nothing worked.
I reconnected the cut wire - nothing.
I connected a voltmeter into the wire and grounded the common side of the voltmeter -- no volts to the light.
This happened one other time when I disconnected the old non working 3rd brake light. I reconnected the brake light wire and NOTHING.
A day later while I was thinking about it, it worked and has been up until today.
I know you will tell me to wait for the magic to work, but this is a safety issue and I want to fix it right.
[quote:e817314556="clreed756"]Brakes problem
1991 Jeep Wrangler 6 cyl Four Wheel Drive Manual 198000 miles
I RECENTLY REPLACED MY BRAKE LIGHTS AND NOW THE BRAKE LIGTHS DO NOT WORK. THE RUNNING LIGHTS AND TURN SIGNALS WORK FINE, JUST NO BRAKE LIGHTS. I REPLACED THE BRAKE SWITCH ON THE BRAKE PEDAL AND CHECKED ALL THE FUSES. ALSO I PUT A METER ON THE HARNESS IN THE BRAKE LIGHT AND PUSHED THE BRAKE PEDAL AND NO POWER IS TRAVELING TO THE HARNESS, NOT SURE WHAT TO DO NEXT, CAN YOU HELP?[/quote:e817314556]
Feb 28, 2009 at 4:36 AM
