1991 Jeep Wrangler bogging down at 2500RPM
1991 JEEP WRANGLER
148,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKELOWRY
Hello all, New to forums but not to Jeeps. Recently talked the wife into letting me buy a 91 YJ. we love it. 6cyl. Automatic. Heres the rub: When revving it up, she starts bucking and shaking at 2500RPM, even with the throttle floored she will not go any higher. The 4wd light was on, but it was in 2wd. now the light seems to go on and off when trying to drive it. She was shifting hard at first and now it seems like theres just no power getting to it, it wont go fast at all and has trouble on the slightest road hill. Flooring it and it will still only get to about 25mph. I've changed the oil and filter, tranny filter and fluid, spark plugs and fuel filter and still the same problem. Any ideas, thanks so much for your Help/Time.
Jun 28, 2010 at 5:50 AM
If the tranny is not slipping do below
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 28, 2010 at 6:05 AM
