[quote:a76c68b73d="airsoftsoldrecn9"]The early Wranglers were actually had the intermediary throttle body injection to replace the problems and complexity with carburation.
Check to see if the pressure regulator is recieving fuel.
Verify the fuel pressure is approximatly 15-20 psi.
If you do not get fuel here trace the line back to the fuel filter and then to the fuel pump. Replace the fuel filter regardless, most likely it has not been unless the previous owner stated this. The fuel pump should hum with the ignition on ACC. If not check the fuse bus under the hood. It will be located in the powertrain distribution block in front of the battery.
If fuel is being recieved check the injector pintle for opening with a small 9v battery or an equivalent small dc source with between 9-12V @ 20mA>. You will need to disasemble the throttle body to gain access to the injector. The solenoid inside the injector should engage and disengage with a quiet click. If not it should be replaced. This may prove to be a bit much so feel free to take this to your local mechanic once you reach this point.[/quote:a76c68b73d]
This Jeep has a regular carb, external fuel pump, I have changed the pump and filter, and the carb is rebuilt and has been on there for almost a year. I think that the carb is bad, it only came with a 3 month warranty, so if I have to buy another one, it certainly won't be the same manufacture. I appeciate your reply.
Jul 1, 2009 at 11:15 AM
