When I run my A/C unit condensation leaks on the floorboard.How can I prevent this?Thanks
Aug 24, 2009 at 10:21 AM
✓Experienced Mechanic
Hi there,
you will need to locate and check that the A/C evaporator drain tube is free as this sounds as if it is blocked and the moisture from the air drawn off is not draining away.
Mark (mhpautos)
Aug 24, 2009 at 10:24 AM
