1989 Jeep Wrangler LEAKS(CONDENSATION)
1989 JEEP WRANGLER
20,000 MILES • 4 CYL • 4WD • AUTOMATIC
ACEYACE
When I run my A/C unit condensation leaks on the floorboard.How can I prevent this?Thanks
Aug 24, 2009 at 10:21 AM
  • 31,937 POSTS
Hi there,
you will need to locate and check that the A/C evaporator drain tube is free as this sounds as if it is blocked and the moisture from the air drawn off is not draining away.
Mark (mhpautos)
Aug 24, 2009 at 10:24 AM
