1988 Jeep Wrangler Hard start & Rough Idle, once warmed
140,000 MILES • 4 CYL • 4WD • MANUAL
WRANGLER88
Basically the Jeep gives all signs that it is flooded when starting, excess fuel and once it fires you have to step on the gas pedal to get it to run. Idles alright when cold, but after it warms up the idle is very rough and will not stay running. Also it will back fire once in a while when shifting between gears.
I initially thought it was the fuel regulator. I have install a new fuel regulator and now it will start (if primed), but will not run.
Jan 7, 2009 at 11:26 PM
BMRFIXIT
  • 19,053 POSTS
Check fuel pressure
Check it for tune up
Disconnect O2 sensor and check if better replace O2 sensor
check MAP sensor
Check for codes cycle key on off on off on check engine will flash codes for you
* ** code 12 ***** ***** code 55 and so on
Jan 8, 2009 at 12:58 AM
WRANGLER88
[quote:c103e7c8a6="BMRFIXIT"]Check fuel pressure
check MAP sensor
* ** code 12 ***** ***** code 55 and so on[/quote:c103e7c8a6]
You indicate that I should check the fuel pressure, but would bad fuel pressure show up at higher speeds. I do not have any problem at that moment.
I do not have any manuals at the moment, where is the O2 sensor located?
Jan 8, 2009 at 7:41 AM
BMRFIXIT
  • 19,053 POSTS
O2 sensor located on the exhaust system
need a pressure gauge set to check fuel pressure
if you have a leaky injector and or low pressure it all should show up on the gauges
High speed demand high fuel flow and constant fuel pressure
Jan 8, 2009 at 8:12 AM
