ENGINE STARTS,BUT SHUTS WHEN I RELEASE IGNITION SWITCH. WILL RUN WITH STARTER FLUID OR GAS PUT INTO THROTTLE BODY MOUTH. I REPLACED FUEL RELAY,PUMP,AND FILTER. IDONT HAVE FUEL PRESSURE GAUGE, BUT SEEM TO HAVE GOOD PRESSURE AT LINE GOING INTO THROTTLE BODY. LOOKED FOR VACUUM LEAKS AND TIGHTENED BOLTS ON INTAKE MANIFOLD.IS THERE A WAY TO VERIFY FOR CERTAIN THAT THERE ARE NO VACUUM LEAKS OR SUCKING AIR AT INTAKE? I ALSO REPLACED THE EGR VALVE. THANKS
Aug 19, 2010 at 7:50 AM
