1987 Jeep Wrangler Clutch loses pressure
REEFYPOOPOO
  • 1987 JEEP WRANGLER
Transmission problem
1987 Jeep Wrangler Manual
Had a new clutch put in about a year and a half ago. About 2 or 3 times since then, the clutch has lost pedal pressure and shifting into 1st gear from a stop was incredibly difficult. The auto shop bled the clutch and refilled it (usually without finding air).
This fixes the problem but apparently its only temporary. I've also noticed some spots on the ground underneath the engine. Thoughts on troubleshooting or suggestions appreciated. Thanks
Thursday, May 8th, 2008 AT 4:05 PM
If the hydraulic lines are not leaking test the clutch master cylinder and slave-
Thursday, May 8th, 2008 AT 4:48 PM
REEFYPOOPOO
Thanks
Friday, May 9th, 2008 AT 2:32 PM
REEFYPOOPOO
Checked my Midas records and they indeed have replaced the master and slave cylinder in the past. There was paint peeling near the master cylinder but I dunno if that was old or not.
So most likely can only be the hydraulic lines unless one of the replaced parts went bad already (unlikely).
Tuesday, May 13th, 2008 AT 1:49 AM
Manufacturer defect/s. How long was the past? Bleed the clutch M/C and see what happens.
Tuesday, May 13th, 2008 AT 5:00 AM
REEFYPOOPOO
Clutch assembly and slave cylinder - May '06
master cylinder - Nov '06
Midas just bled the clutch like a week ago when it wasn't working. They said they found no air.
Tuesday, May 13th, 2008 AT 3:34 PM
Hydraulic pressure starts at the master cylinder-have they tested it-
Wednesday, May 14th, 2008 AT 5:25 AM
