stiff clutch pedal
2015 JEEP WRANGLER
25,000 MILES • 3.6L • V6 • 4WD • MANUAL
RYAN FOWLER
Clutch pedal last night was super soft halfway threw stroke and was kind of stuck in gear. Today the clutch pedal is super stiff all the way through the stroke.
Oct 29, 2016 at 5:47 AM
  • 31,937 POSTS
Proberbly air getting into system, check back of master cylinder for signs of leaks and under dust seal boot on slave for fluid, if fluid is seen replace item and re-bleed.
Oct 29, 2016 at 12:04 PM
