Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
CJ7
Engine
Symptoms
Not Running
Will not start
1984 JEEP CJ7
98,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
CRAIG STEADMAN
MEMBER
1 POST
The car cranks but will not start. It is getting gas to carburetor. I tested the coil and it is good.
Aug 27, 2018 at 11:52 PM
Experienced Mechanic
Good morning.
It sounds like you have no spark.
Does this have points or is it electronic ignition?
If you coil is putting out spark, did you test for spark to the plugs?
Aug 28, 2018 at 1:07 AM
CRAIG STEADMAN
MEMBER
1 POST
Thank you Roy,
I will look into your questions and get back to you.
Craig
Aug 28, 2018 at 3:28 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
