will not start
150,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
WILLIE1955
The vehicle first started not starting all the time. It has a new fuel pump, crank sensor, cam sensor, starter and spark plugs. Now, it is getting sparks but will not fire. Any advice would be appreciated. Thanks.
Mar 11, 2017 at 9:52 AM
HMAC300
  • 48,601 POSTS
then scan for codes see if anything comes up and check fuel pressure. is spark good like blue and not a weak spark? check fuses under hood and ASD relay. then try stuff on link here.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Mar 12, 2017 at 3:42 AM
WILLIE1955
We are stumped. It is getting fuel. It will not start even with ether.
Mar 12, 2017 at 4:20 AM
  • 55,770 POSTS
It sounds like it might have jumper time, can you do a compression test to see if the engine has any?
Please run this test and get back to us so we can continue helping you.
Best, Ken
Mar 13, 2017 at 7:52 AM
WILLIE1955
I'll relay your message to my husband. Thank you for responding.
Mar 13, 2017 at 12:33 PM
  • 55,770 POSTS
Please let us know what you find so it will help others.
Best, Ken
Mar 14, 2017 at 4:41 AM
WILLIE1955
Just wanted to let you know, my husband will be trying what you suggested about the timing chain. He has a friend who is a mechanic who is helping him this week. We will let you know what happens. We really appreciate your help.
Mar 20, 2017 at 11:47 AM
WILLIE1955
There is no compression. You were right! They are going to fix it next week. I don't think they are looking forward to it.
Mar 22, 2017 at 8:28 AM
  • 55,770 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ken
Mar 22, 2017 at 11:48 AM
