1999 Jeep Wagoneer Jeeps Dies after idle for 30min
1999 JEEP WAGONEER
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
DENNIS BLOXHAM
I have changed the fuel pump, distributor cap and rotor, starter relay, fuel pump relay, coil, cam shaft position switch. My jeep will run for about 30 mins and just quit. No warning, doesn't sound like its starving for fuel. No alarm system. Checked all wiring to every connecter. Auto Zone found check engine code for "Engine Temp relay switch" error. I have not replaced the crank position device, but just had the transmission rebuilt.
Oct 27, 2008 at 10:53 AM
MASTERTECHTIM
  • 4,750 POSTS
first thing to change is a condition like this is the crankshaft postion sensor. 99 percent of heat related no starts. hope this helps
Oct 27, 2008 at 11:59 AM
