Hi, my gas gauge is not working. I filled the tank and it didn't move from the empty spot. Thank you for your help..
Oct 30, 2008 at 7:58 AM
REDJEEEP
MEMBER
it sounds like your fuel level sensor finaly broke
it just needs to be replaced or the ground has a bad connection i would check that first but most likely the sending unit is bad
Nov 2, 2008 at 1:42 AM
