1990 Jeep Wagoneer key lock
192,000 MILES • 6 CYL • 4WD • AUTOMATIC
TEXAS17
is it necessary to remove the steering wheel to replace a key lock? it is locked in the on postion, I had to remove the coil wire to turn it off and now can not get the shroud off of the column to replace the lock
Aug 28, 2009 at 9:36 AM
  • 110,246 POSTS
THe steering wheel needs reoved to access the tumbler.
Aug 28, 2009 at 10:06 AM
