1990 Jeep Wagoneer changing engine mounts
1990 JEEP WAGONEER
150,000 MILES • V8 • 4WD • AUTOMATIC
CCOHEN1
we are changing all mounts on a 1990 wagoneer V8 360, only to find out that the engine ones cannot be remove using a regular tools, i am talking about the bolts on the engine side. Is there a trick to be able to have these bolts removed or does it really need a special key/range/tool ?
Maybe someone can point the direction to some instructions on that removal
Thnx
Claude
Jan 2, 2008 at 10:21 PM
2CARPRO JACK
  • 11,533 POSTS
Dont see any specific instructions on how to do it or what is req'd. Sometimes 1/4 inch drive sockets help. Also want to get as much room as possible between the mount and the frame to gain access
Jan 3, 2008 at 3:54 AM
