1989 Jeep Wagoneer changing water pump
1989 JEEP WAGONEER
18,000 MILES • 6 CYL • 4WD • AUTOMATIC
RED2000GUY
I own a 1989 jeep wagoneer limited with a V6 engine. I need to change the water pump but for some reason I can't figure out how to take the belt off. idk call me stupid lol but I can't for the life of me find the tensioner. If u could help that would be great thankyou
Mar 8, 2009 at 1:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
To remove the serpentine belt from your vehicle, perform the following operations..
REMOVAL:
Loosen the rear power steering pump mounting bolts using a ratchet and 13mm socket or a 13mm box wrench.
Loosen the pump upper pivot bolt, lower locknut and the pump adjusting bolt using a ratchet and 13mm socket or a 13mm box wrench.
Remove the belt.
INSTALLATION:
Install the belt.
Tighten the pump adjusting bolt to achieve proper tension.
Install the pump rear mounting bolts, pivot bolt and locknut. Tighten the bolts to 20. ft. lbs. (27 Nm).
Check the belt for proper tension. If tension is incorrect, adjust tension as needed.
Thanks for using 2CarPros.com!
Mar 8, 2009 at 4:37 PM
