1989 Jeep Wagoneer backfire
GRUMPY0800
Engine Performance problem
1989 Jeep Wagoneer 6 cyl Four Wheel Drive Automatic
when i turn left and accelerate it backfires and lacks power then clears up after a few seconds and is fine
Mar 7, 2009 at 7:23 AM
BILLYMAC
  • 2,204 POSTS
hi either the fuel sending unit is damaged or pump is failing check fuel pressure if ok remove tank and sender repair pick up tube
Mar 9, 2009 at 7:26 AM
