1988 Jeep Wagoneer 1988 jeep wagoneer stalls while idling
175,000 MILES • 6 CYL • 4WD • AUTOMATIC
HAMMER13
My 1988 jeep wagoneer randomly stalls while idling or driving at low speeds (through parking lots for example). I have changed the ignition control module and fuel filter but still have the problem.
May 23, 2010 at 8:19 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay -clean out the idle air control valve/motor/ISC and EGR and PCV valves and test the throttle position sensor.
May 26, 2010 at 6:03 PM
