1988 Jeep Wagoneer
DOGSGIRL
Engine Cooling problem
1988 Jeep Wagoneer 6 cyl Four Wheel Drive Automatic
what would cause it to overheat after the thermostat, water pump, and antifreeze have been changed and added?
Jun 2, 2009 at 3:26 PM
  • 75,988 POSTS
If the radiator is not clogged up you should bleed the cooling system and see what happens if it continues get it block and pressure tested to rule out a blown headgasket, cracked head or block /intake manifold leak
Jun 2, 2009 at 10:01 PM
