1988 Jeep Wagoneer
1988 JEEP WAGONEER
DOGSGIRL
Engine Cooling problem
1988 Jeep Wagoneer 6 cyl Four Wheel Drive Automatic
what would cause it to overheat after the thermostat, water pump, and antifreeze have been changed and added?
Jun 2, 2009 at 10:26 PM
If the radiator is not clogged up you should bleed the cooling system and see what happens if it continues get it block and pressure tested to rule out a blown headgasket, cracked head or block /intake manifold leak
Jun 3, 2009 at 5:01 AM
