HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Wagoneer
Engine
Symptoms
Low Power
1987 Jeep Wagoneer
CHRIS MATA
MEMBER
1987 JEEP WAGONEER
Engine Performance problem
1987 Jeep Wagoneer 6 cyl Four Wheel Drive Manual
Vehhicle turns on and idles fine but when accelerate it starts bogging down and back fires.
Monday, March 9th, 2009 AT 2:20 PM
BILLYMAC
MECHANIC
Hi check the fuel pressure if ok scan for codes most likely a sensor failing
Monday, March 9th, 2009 AT 2:23 PM
CHRIS MATA
MEMBER
Tuesday, March 10th, 2009 AT 8:20 AM
Please
login
or
register
to post a reply.
Related Engine Low Power Content
1989 Jeep Wagoneer Bogs Down When Starting Out
Help! Have All New Plugs, Wires, Distrib Cap And Roter. But When Starting Out From Stop, She Bogs Down Or Stalls. Injection Problems...
Asked by
popelka46
1 ANSWER
1989
JEEP WAGONEER
VIDEO
Fix an Engine with Low Power!
Instructional repair video
GUIDE
Symptoms of Low Engine Power
The power your car's engine is producing is important. When you step on the gas you need your car to accelerate, mainly to keep you out of trouble when getting onto the...
1984 Jeep Wagoneer No Acceleration Power
When I Start My Jeep, And Put It Into Gear, I Can Either Mash The Accelerator Down, Or Ease It Down, But It Will Only Very Gradually Get...
Asked by
joerowlen
1 ANSWER
1984
JEEP WAGONEER
Engine Cranks But Does Not Start
Replaced Ecm, Carb Rebuilt, New Wires, New Coil, Rotor And Cap New. New Remote Starter, And New Fuel Pump. Plus New Air And Fuel...
Asked by
Paul Marion
1983
JEEP WAGONEER
Back Fire
Below 2000 Rpm It Back Fires And Cuts Out
Asked by
bighand
1989
JEEP WAGONEER
1988 Jeep Wagoneer 1988 Wagoneer Starting Problems
My 1988 Jeep Wagoneer 6 Cylinder Has A Random Problem Of Not Starting, Usually After A Trip Somewhere Like To The Store Or Church. If You...
Asked by
hammer13
1988
JEEP WAGONEER
VIEW MORE
Catalytic Converter Test
