I removed the distributer and i would like to know how to time it.
Sep 10, 2010 at 4:57 PM
✓ASE Certified Mechanic
Remove the distributor-put engine piston no.1 on compression stroke/TDC then line the crankshaft pulley mark to 0/TDC and timing scale then install the distributor making sure the rotor is pointing to no.1 cap tower
Sep 10, 2010 at 8:18 PM
DAN O'QUINN
MEMBER
In 2005, jeep do not have a rotor button or marks on ballancer, crankshaft sensor is connected to distributer, ther is another way I'll find out eventually thanks.
Sep 11, 2010 at 7:58 AM
