2005 Jeep TJ distributer timing
2005 JEEP WRANGLER TJ
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAN O'QUINN
I removed the distributer and i would like to know how to time it.
Sep 10, 2010 at 9:57 AM
Remove the distributor-put engine piston no.1 on compression stroke/TDC then line the crankshaft pulley mark to 0/TDC and timing scale then install the distributor making sure the rotor is pointing to no.1 cap tower
Sep 10, 2010 at 1:18 PM
DAN O'QUINN
In 2005, jeep do not have a rotor button or marks on ballancer, crankshaft sensor is connected to distributer, ther is another way I'll find out eventually thanks.
Sep 11, 2010 at 12:58 AM
