2004 Jeep TJ Transfer case lowering kit
SBJWHITE
Suspension problem
2004 Jeep TJ 6 cyl Four Wheel Drive Automatic
Installing a lift kit to my 2004 Jeep Wrangler.
Was installing drop spacer between frame and skid plate when the weld busted that holds the bolt to the frame. Have everything else installed but that one bolt. Can't back the bolt out or screw it in because the weld is busted preventing it.
Feb 22, 2010 at 11:54 PM
PELON99TJ
  • 8 POSTS
[quote:e9ff2df5af="sbjwhite"]Suspension problem
Was installing drop spacer between frame and skid plate when the weld busted that holds the bolt to the frame. Have everything else installed but that one bolt. Can't back the bolt out or screw it in because the weld is busted preventing it.[/quote:e9ff2df5af]
I ran mine with 5 bolts for about a year. ARe you planning upgrading to a SYE? If so you will need to cut it off and weld a bolt back.
Apr 14, 2010 at 5:53 AM
