2004 Jeep TJ multifunction switch
74,000 MILES • 6 CYL • 4WD • AUTOMATIC
DANS10.98
factory fog lights stay on all the time...switch is off, keys out of ignition...turn left turn signal on they go off...so i figured multifunction switch has gone bad...picked one up at local dealer...installed, now fog lights work fine but i have no turn signals or flashers...installed old switch and they work fine...everything on old switch work except fog light problem..does the new switch need to be programmed at the dealer....thanks
Aug 25, 2009 at 5:09 PM
CJ MEDEVAC
  • 11,000 POSTS
From experience, EVEN NEW STUFF CAN BE BAD......hope you get her fixed
Oct 8, 2009 at 8:32 AM
