2004 Jeep TJ Changing Differential oil
44,000 MILES • 6 CYL • 4WD • AUTOMATIC
MICTRIK
I notce than many shops (including dealerships) do not remove the differential covers when changing the differential fluid. I believe they pump out the old oil. would this be considered a shortcut and would it be likely to cause problems "down the road"? Please forgive the pun...
Feb 26, 2009 at 7:03 AM
  • 75,988 POSTS
You'll be fine-I prefer that method it will sucked everything out and properly filled with the correct weight gear oil then to drain it and end up some debris will stay back-
Feb 26, 2009 at 7:13 AM
