2003 Jeep TJ rear differential leak from vent tube
2003 JEEP WRANGLER TJ
79,000 MILES • 6 CYL • 4WD • MANUAL
REDFIREMAN
I have started having gear oil under the left rear corner of the jeep with it running down into the gas tank skid plate. I changed diff covers about three months ago but this just started this week. I had the vent tube come loose once when it was under warranty. Where is the end supposed to be so I can confirm that that hasn't happened again before going into the shop.
PS there is no leak in the area of the diff.
Oct 8, 2009 at 9:03 AM
PELON99TJ
  • 8 POSTS
Do you have a locker or open? If you are open you may need a additive to the gear oil.
Apr 14, 2010 at 3:26 AM
REDFIREMAN
It's an air-locker. it's an intermitent problem now. I know the diff isn't over filled.
Apr 16, 2010 at 1:38 AM
PELON99TJ
  • 8 POSTS
Sound like it was over filled.
Apr 18, 2010 at 3:17 AM
