Hi, I have a problem starting my Jeep. It was working fine then one day it decided to turn over but not start. I check all the fuses..good. I noticed when I put the key in the ignition to one I sometimes hear the realys and fuel pump kick in. If they do not then my gauges don't move, if the relays and fuel pump run then the gauges turn on and I have to keep the gas petal pressed in order to start. If I do not keep the petal pushed then it will turn over but not start. Once it starts then I have to keep the petal depressed until it warms up...no idle. I have replaced the battery and CKP sensor....what next?
Feb 28, 2010 at 11:09 AM
