2001 Jeep TJ right blinker is on steady when ever the light
2001 JEEP WRANGLER TJ
85,000 MILES • 6 CYL • 4WD • MANUAL
JEEPBLINKER
when the lights are on the right blinker indicator is continuously on (not blinking). the side lights are brighter on the right. but when the switch is thrown the lights do blink. when the switch is in the neutral position or the left position the right indicator is on steady and after a few seconds the buzzer sounds to turn the blinker off. the only thing that makes the buzzer stop is turning the lights off and back on (not safe at night).
does any one have any advice?
any help would be greatly appreciated
Thanks,
Feb 25, 2010 at 9:32 AM
CJ MEDEVAC
  • 11,004 POSTS
POSSIBLE HELP ??!!--------See my profile--------INSURE your bulbs (all that may be involved) are all the way in..... CORRECTLY!!!! (NOT just jammed in any old way)-------If NO-GO-------run temporary jumper from NEG GRD BATT to housing/ NEG on wire/ to bulb/ touch GRD screws/ etc. that grounds that system---TOUCH ONLY-ONLY-ONLY GROUNDS !!!!!!!!!!......If one of these operations makes it work........Repair that problem (the faulty ground).......Like I said, "POSSIBLE HELP"
Love, Turddog
Feb 26, 2010 at 4:12 AM
