2000 Jeep TJ Wheel Bearings
2000 JEEP WRANGLER TJ
104,563 MILES • 4 CYL • 4WD • MANUAL
STEVE2010
2000 Jeep Wrangler TJ. Was drivng down the road going about 65MPH, and my steering wheel starting shaking so much I thought I was going to roll it. Does this have something to do with wheelbearins
Jul 6, 2010 at 10:58 AM
JONYQUEST
  • 10 POSTS
No. bearing are most likely not the problem. If you have bigger tires on it like mud tires or something, they are probably the cause. If not Jeeps are famous for steering stablizers and track bars going bad causing a vibration. Its easy to replace. I would try that first.
Sep 28, 2010 at 8:24 PM
