2000 Jeep TJ
2000 JEEP WRANGLER TJ
79,000 MILES • 6 CYL • 4WD • MANUAL
TETOS
how replace the pcm and it works
Jan 30, 2009 at 4:44 PM
BMRFIXIT
  • 19,053 POSTS
it should start up and run but you will set an ABS codes and light will be on until coorrect VIN is entered
If PCM has been replaced and correct Vehicle Identification Number (VIN) and mileage have not be entered into new PCM, Diagnostic Trouble Codes (DTC) will set in Anti-Lock Brake (ABS), air bag and Sentry Key Immobilizer Module (SKIM). Secret key data must be updated prior to starting vehicle.
Jan 30, 2009 at 10:28 PM
