Hi Seth,
Thank you for the donation and sorry for the delay in replying.
You have an issue with the taillight and interior illuminations which are in the same circuit.
With lighting switch turned ON, test if you have battery voltage at terminal #9 ( Black/Yellow wire ). Battery voltage should be present.
If no voltage is present, test terminal # 4 ( Tan/Black wire) and if voltage is present, the switch is faulty. Was the lighting switch replaced new or used?
If voltage is available, check Fuse # 1 (20 A ) in fuse box. Check continuity btween fuse and lighting switch if fuse is good and has voltage at both ends.
SPONSORED LINKS
Friday, November 20th, 2009 AT 4:36 PM
