1998 Jeep TJ transmission noise
118,960 MILES • 6 CYL • 4WD • MANUAL
ACECASS
My 98 wrangler is making a loud klunking sound when I back up. There is a little noise in forword. But no klunking.
Nov 30, 2008 at 5:30 AM
MECHCURT
  • 184 POSTS
Try and get the rear wheels up in the air. BE CAREFUL use jack stands and ensure the vehicle is safely in the air. Have a friend help you and put it in reverse and then forward and listen to see where the noise is coming from. AGAIN be careful getting under a running vehicle. Just trying to get a better idea of where the noise might be coming from , Posty back when you have done this and maybe we can come up with a good answer to the problem. Thanks Curt
Dec 4, 2008 at 6:46 AM
