1998 Jeep TJ Belt squeaks when the ac or defrost is on
1998 JEEP WRANGLER TJ
118,000 MILES • 6 CYL • 4WD • MANUAL
BEALEM
Everything runs great until i turn on the ac or defrost, then the belt will squeak and the battery meter drops to 9. Is the idle control valve bad?
Feb 4, 2010 at 4:02 AM
CJ MEDEVAC
  • 11,004 POSTS
Really sounds like either you AC belt is not tight or WORSE, Your AC compessor/ clutch is locked up and is basically slipping/ burning the belt off
AC/ DEFROST modes activate Mr. Clutch/ Compressor
..........Love Turddog
Feb 17, 2010 at 3:34 PM
