I have had a problem with my vehicle now for a couple months when it got up to temperature and was hauling a trailer it would start missing and in reverse if you jumped into the pedal it would spit and sputter. I replaced the crank position sensor four days ago and both problems went away. I have drove it about three hundred miles and it has been fine then i get home i go to back it into the drive and its start missing again. I replaced the crank sensor once again thinking i might of got a bad one since all problems went away when i replaced it a couple days ago but this time it did not fix the problem. If i put it in forward and punch it until burn the tires, if i put it in neutral or park and chop the throttle it will go as i as it wants with no hesitation what soever as well. if i put it in reverse it idles fine and if i push the gas but keep the rpm's under 1000 it is fine, but as soon as it hits a grand its all over the map. I am completely stumped. Does anyone have any clue what might be wrong? I can work on cars no problem but i suck at troubleshooting.
Apr 25, 2017 at 10:03 PM
