Engine shuts off
180,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
DERRICK POOHDUB HOLT
I have the Laredo model. The security only lets it run for a second then shuts down. I grounded the violet and yellow wire which worked for a month. now it is doing that again and I do not have a remote for the alarm. how can I get it to run? I have to move it today.
Aug 13, 2017 at 1:40 AM
CARADIODOC
  • 34,415 POSTS
Lock, then unlock a front door with the key to turn the anti-theft system off. If that doesn't work, suspect broken or frayed wires between the door hinges. There can be a linkage disconnected to the switch in the door too, but broken wires are much more common. One potential clue, when a wire isn't totally broken yet, is the function may work intermittently when moving the door between open and closed while operating that system.
Aug 14, 2017 at 10:34 AM
