1984 Jeep CJ-7 Headlights Not Working
JEEP
YUKON12
I have an 84 jeep cj 7 with 171000 miles on them. The headlights are not working and I have switched out every fuse and the dimmer switch twice. Is there a relay or something for this that I can not find? I have traced the wires as best I could to the fuse box and didn't see anything. They were working before so this driving me crazy. The parking light markers are working and everything else is fine.
Dec 15, 2006 at 11:32 AM
CARUNDELL
  • 602 POSTS
[quote:bccab2ca03="yukon12"]I have an 84 jeep cj 7 with 171000 miles on them. The headlights are not working and I have switched out every fuse and the dimmer switch twice. Is there a relay or something for this that I can not find? I have traced the wires as best I could to the fuse box and didn't see anything. They were working before so this driving me crazy. The parking light markers are working and everything else is fine.[/quote:bccab2ca03]
Hey yukon,
Verify power and grounds for the headlights, I suspect you may have a ground issue Let us know!
Chris
Dec 15, 2006 at 9:21 PM
YUKON12
Checked every ground and lead along with changing out my light switch. The last thing I checked, the high low beam switch and that was it. :roll: 2 weeks of driving with fog lights waiting for the light switch to come in and 5 hours of testing every possible thing and it comes down to a 4.99 part that takes 5 minutes to fix. :idea: :!:
Jan 4, 2007 at 4:31 AM
Suggested Repair
Verify headlight power and grounds. The owner later found the high/low beam switch was the failed part and replaced it.
Conversation Summary
A 1984 Jeep CJ-7 had inoperative headlights while the parking lights and other systems worked. Fuses, the light switch, and the dimmer switch had already been replaced, and wiring to the fuse box was traced. The expert advised checking headlight power and grounds, suspecting a ground problem. After further testing, the owner reported that the high/low beam switch was the cause and that replacing the inexpensive switch restored the headlights.
