2006 Other Jeep Models Gas pumps do not shut off when tank i
2006 JEEP
13,000 MILES • 6 CYL • 4WD • MANUAL
YVONNERMW
My husband drives a 2006 Jeep Wrangler-Unlimited-last year they made a straight 6 in this model. The problem is when filling the gas tank, the pump does not shut off when the tank is full. Therefore, spewing out gas all over the place! What could cause this to happen? Is there a sensor in the gas can that could be bad??
Any advice is greatly appreciated!
Thanks,
Rose Warneford
Oct 21, 2008 at 3:58 AM
JNOVACK
  • 723 POSTS
do you use the same gasstation all the time or is this at randum stations but sometimes the gas comes out so fast that when it does shut off it does spash some out but if the pump just doesn't shut off iti is the pump nozzle there is nothing wrong with your jeep it is the gas pump
Oct 21, 2008 at 11:53 AM
YVONNERMW
This happens at all gas stations. That's why I was wondering if something is wrong with the gas tank.
Oct 22, 2008 at 6:40 AM
JNOVACK
  • 723 POSTS
no mam the gas pump should shut off on its on but I see the jeep I am a jeep mechanic and I have never seen this happen but I see the jeep is still under warrenty I would take to dealer and bring up this issue you may not be the only one haveing this probblem and if there is something wtrong with the tank they need to know so the probblem can be fixed I discused this with my service manager and that is all we can give you for advice sorry
Oct 22, 2008 at 8:44 AM
