2005 Other Jeep Models 2005 Jeep Grand Cherokee won't start
2005 JEEP
70,000 MILES • V8 • 4WD • AUTOMATIC
DREDAM
Drove the Jeep into work today and when I just went out to try to start it, it won't start. When you turn the key it "clicks" once and then nothing. Interior lights work fine, headlights work fine, tried the horn with those on and that works fine. Any ideas?
Thanks!!
Don
Nov 14, 2008 at 5:49 AM
JNOVACK
  • 723 POSTS
check the grounds mostly the one that runs from the fram to the exhaust to the transmission jeep has a bad probblem with that ground and if they are all ok then pull starter off and have it tested also check to see if you are getting enough power to the starter
Nov 14, 2008 at 2:51 PM
