2005 Other Jeep Models
ASMONKEY
  • 2005 JEEP
Transmission problem
2005 Other Jeep Models 6 cyl All Wheel Drive Automatic
i have a 05 jeep rubicon with a busted transfer case (NP241J) but I also have a chevy transfer case(NP241C) can I put that transfer case in my jeep?
Monday, October 20th, 2008 AT 1:13 PM
MECHCURT
  • 184 POSTS
The NP241 was used in Dodge, Jeep Chevy starting in 87. Now youi can usually swap jeep and dodge ok but the gm 241, bolt pattern is clocked about 90 degree's off. Same number of bolts but the case is turned. Look at it and compare and I am sure this is what you will see. The chevy transfer case is good trading material tho so if it will not work I would try and trade it for one that fits the Rubicon. Hope this helps Curt
Tuesday, December 2nd, 2008 AT 11:19 PM
