2002 Other Jeep Models alignment
2002 JEEP
120,000 MILES • V8 • 2WD • AUTOMATIC
SAVAGENATION07
I am looking to have some tires put on my jeep but dont have the money right now, i know my alignment is bad because the car drifts to the right on the freeway, my service advisor said that we need to do the tires before we do the alignment or the alignment angles will change once the new tires are put on... can alignment be done before new tires are installed or will this effect the alignment?
Jan 27, 2009 at 2:38 AM
JASONRAY
  • 213 POSTS
The alignment can be performed before the new tires are installed, however, if the tires that are on the vehicle NOW have worn irregularly due to the alignment angles being wrong, the vehicle may still pull to one side or the other. The alignment machine will tell the technician where to set the angles. It doesn't care what kind of tires are on the car. The tires will not change the angles or settings but they CAN effect how the car drives. If you must have the alignment done now to lengthen the life of the tires, at least rotate them and then do the alignment. Put the tires that are on the front on the rear and vice versa. This will give you 'somewhat' of a new start with the new settings on the front end. Then, when you can afford it, replace the tires. Also, you might consider replacing just 2 of the tires (front) now and the other 2 later. Replace the 2 worst tires but make sure the new ones go on the front.
Jan 27, 2009 at 6:42 AM
