2001 Other Jeep Models Ilde low
2001 JEEP
85,000 MILES • 4 CYL • 4WD • AUTOMATIC
ROBINHOOD795
My jeep grand cherokee start with idle is low when it's move and stop engines dies. I call the breakdown company they just reset the engine by removing the negative wire from the baterry. and its ok again after a week problem returned. thier no error code in scanner. i replaced the tps still the same.
Nov 17, 2009 at 3:31 AM
MICKEY-D
  • 304 POSTS
It sounds like a fuel problem. Change the fuel filter, and check the fuel pressure. You could have a bad fuel pressure regulator.
Dec 16, 2009 at 4:14 PM
