2001 Other Jeep Models drain
2001 JEEP
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
IRMA1955
my 2001 jeep grand cherokee's a/c drain keeps getting clogged water keeps coming into floor inside instead of out. I have uaed a wire hanger to try and unclog but the wire only goes into like an 1in into rubber drain hose on the firewall.can you help?
Jun 6, 2009 at 3:48 AM
MERLIN2021
  • 17,250 POSTS
Sounds like the evap core and box has gunked up the drain hole, open the hood, look on the right side by the windshield, remove the plastic shiel under the right wiper arm, see if you can see the a/c evap core, if not remove any filters, and fan motor, this should expose the top of the core, get a can of evaperator core cleaner at an a/c heating plumbing supply hose and spray it into the evap case, you wait 20 minites or so and rinse with water, should help...
Jun 6, 2009 at 3:55 AM
