2000 Other Jeep Models Noise in grand cherokee limited
2000 JEEP
100,000 MILES • V8 • 4WD • AUTOMATIC
LOAIELGAZAIRLY
My car is 2000 jeep grand cherokee limited V8 all wheel drive, Two questions:
1) The car is all time 4x4 and on tide curves, such as parking, the front wheels shake/viberate. I did the differential service and the dealer told me it is normal since the outside wheel is turning on larger radious?
2) I hear a clicking noise while opening the driver door. I followed the noise and it was the piece holding the door to the body and it was snapping. I was told it is the Door Check and it needs replacement. To do that the door panel needs to come out. Is that true?
Jun 16, 2009 at 5:58 AM
RACEFAN966
  • 5,029 POSTS
Ok the turning vibration depends on how tight the turn and what speed. Now as for the door stop I don't believe you have to pull the panel I didn't on my 99 Jeep Grand Cherokee. It was just two screws on one side and a pin on the other if I recall right. I can look again if needed.
Jun 17, 2009 at 3:04 AM
