1999 Other Jeep Models starter?
1999 JEEP
153,000 MILES • V8 • AWD • AUTOMATIC
RADIATOR
When I try to start my Jeep, sometimes it doesn't do anything. I'll turn the key on, all the gauges come, but when I try to start it, it doesn't even try and turn over, just nothing, no sounds, no clicking, nothing. I'll keep trying every couple of minutes and it will eventually start up.
Dec 12, 2007 at 12:02 AM
2CARPRO JACK
  • 11,533 POSTS
Need to start by checking your battery connections, be sure they are tight and clean.Then test for 12 volts at the small wire on the starter when key is in crank position.If it has it, then the starter is bad, if not get back to me and we can go from there
Dec 12, 2007 at 5:54 AM
