1999 Other Jeep Models no spark
1999 JEEP
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
EKRUEG
my 99 jeep grand chrokee has no spark what can be the cause can it be the ecm
Feb 11, 2009 at 5:32 AM
JDL
  • 16,098 POSTS
Do you have the rail coil, 4 wire primary connector? One is B+, with the engine cranking, the other 3 are grounds, one ground for each coil, one coil fires two plugs. If you do alot of cranking, you might disable the injectors, or the fuel system, so the cylinders don't fill with gas.
At some point you may need to check for injector pulse, the injector doesn't need to be plugged in for that. If you have no spark and no injector pulse, it may be a sensor problem.
Feb 11, 2009 at 6:34 AM
